NI TestStand
Preventing a Test Report From Being Created (From Withing The Main Sequence)
Hi everyone, I am running Test UUTs to run my "main sequence" file.  I have a step in my sequence that asks the operator to scan a barcode.  If the barcode is not valid I have a Test Stand message prompt that asks the operator if they would like to scan the barcode again or exit the test.  I notice if the operator selects exit test that the main sequence will immediately go to the cleanup (as I tell it to) and exit testing.  However, when the operator selects exit test a test report is still created.  How do I get the Test Report to NOT create if the operator hits exit test?
Thanks so much!
(5,034 Views)
You should consider moving your serial entry dialog to PreUUT.  A report will not be creating if they cancel from within there.
There's an example here: http://zone.ni.com/reference/en-XX/help/370052N-01/tsexamples/infotopics/process_model_parallel/
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,020 Views)
Sorry I meant this link: http://zone.ni.com/reference/en-XX/help/370052N-01/tsexamples/infotopics/callbacks_preuut/
jigg
CTA, CLA
testeract.com
(5,019 Views)
Jiggawax,
Thanks for the response.  Is there anyway within the main sequence to do this?  Or is this not possible?
(4,975 Views)
It is possible but probably not worth it.  You would need to get access to a Root (process model) variable.  So something like RunState.Root.Locals.ReportOptions.
Which version of TestStand are you using?  That could make a huge difference.
jigg
CTA, CLA
testeract.com
(4,969 Views)
Test Stand 2013
(4,964 Views)
Are you using On The Fly reporting?  It will be too late in the MainSequence if you are.  You will have to go delete them off the disk.
Are you just concerned about the results being put on the report?  If so then just clear out your MainSequence Locals.ResultList.
Because everything is in Plugins it is not as easy to turn off report generation dynamically.
jigg
CTA, CLA
testeract.com
(4,938 Views)
