NI TestStand
Preview Sequence in Execution View
I have created a simple LabVIEW UI that runs a TestStand sequence and displays the sequence in an Execution View while it is running. Is it possible to display a preview of the sequence prior to execution?
(525 Views)
Accepted by topic author al_g
I think I have found most of a solution here: Display the Sequence Steps of A TestStand Sequence in LabVIEW
It doesn't seem to be able work with both the Execution View as used for execution and preview.
(497 Views)
