NI TestStand
Print Failure on Label
Hi, at the and of the test, in case of a failure, I have the need to print the failure message on a Label. I have to print: SequenceName, testName, measure, limit high, limit low.
Is there something already implemented in TestStand? What is the correct approach, should I use the "SequeneFilePostStepFailure" callback?
Thanks a lot.
(4,472 Views)
Hi Logatto
If this is my task, i would use the "PostUUT" callback for printing the label.
For collecting the failure stuff during test i would use  "SequeneFilePostStepFailure" callback that you mentioned,
extract what i need and store it in a FileGlobals container.
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,456 Views)
Ok, thanks. Some more doubts.
How can I pass to the to "SequeneFilePostStepFailure" callback the information of the step who called it? For Example Step Name. Or more important, how can I know if the type of the step is numeric limit Test, pass/fail, multiple...?
Thanks a lot.
(4,427 Views)
TestStand will automatically provide the step data.
Check the Parameters of the Callback, there you will find all the stuff you need.
Regards
Juergen
--Signature--
(4,425 Views)
Correct, I did not realize that the parameters are filled in runtime.
The only thing I cannot find is the name of the step who calls the callback. Can you give me a suggestion?
Thanks a lot
(4,419 Views)
Accepted by topic author logatto
Try to use "Parameters.Step.Name"
Why you won't see it?  Because you are accessing the Object Step. and its Property Name
For more info look in TS-Help under Index "Step"
In this Thread there is a nice Example about this callback
http://forums.ni.com/t5/NI-TestStand/Repeating-a-Failed-Sequence-once-more/m-p/1042268
Regards
Juergen
--Signature--
(4,408 Views)
Thanks. You addressed me to to the right way.
(4,390 Views)
