NI TestStand
Problem Using C++ DLL in TestStand
Hi.
I am trying to load a C++ DLL into a DLL call in TestStand. The attached picture shows you the problem that I am having.
I call this exact same DLL in LabView code using the Call Library Function Node and it works perfectly.
Any ideas as to why TestStand doesn't like it?
Thanks.
(3,163 Views)
This message only says, that no parameter information is available. You have to configure the parameters manually.
This should be no problem - simply look at your LabVIEW VI: It can tell you each parameter's name and data type.
Regards, Guenter
(3,155 Views)
