04-25-2008 06:49 PM - edited 04-25-2008 06:53 PM
04-26-2008 07:58 AM
04-27-2008 12:15 PM - edited 04-27-2008 12:16 PM
04-28-2008 12:24 PM
09-13-2013 01:07 PM
Ray,
Could you please send me the vi for this example. I am using LabVIEW 2012 and the PropertyObject (GetType) you specify is not in the lastest LabVIEW.
Thanks.
09-13-2013 02:18 PM
Hey Angel22,
The GetType method is deprecated, and while it will still work in old VIs which used it, it's not available for use in new VIs. Here's the current best way to do it:
This should have the same effect as the GetType() method. Let us know if you need any more assistance!
09-13-2013 02:55 PM
Hi Daniel,
Thanks for your reply. I will like to be able to add a user to a group (Say, Operator). I have been able to create the user but I am unable to add the created user to the Operator group so that they can run a sequence. How can I make this happen. I attached part of my code. Please, advice.
Angel
