NI TestStand
Problem loading Labview 2009 vi into teststand 3.1.
I have made a build using labview development system 2009. I can invoke and run the labview VI's in teststand3.1 by selecting Adapter development system in teststand. But when i configure the adapter in teststand to labview runtime engine 9.0 it gives a problem. The error message is "System Level Exception. [Error Code: -17502]". I think problem with loading labview varaibles . Please let me know how to slove the issue.
Thanks in advance.
Kris.
Test engineer
(3,781 Views)
Kris,
i think you will find this information useful. Please note that it is a link of ni.com/teststand.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,779 Views)
Hi Norbert,
Thank you for the reply. If i understand correctly you sent me the compatability of teststand and labview  versions. From the link it states that i can't use teststand 3.1 to load labview Vi's at all. But i am able to load and run the VI's configuring Labview Development system in Teststand 3.1.  I have a problem only when i configure teststand to labview runtime 9.0.
Thank you in advance.
Kris
Test engineer
(3,771 Views)
Kris,
no, this link only displays what combination of LV and TestStand is supported. Since TestStand 3.1 is not listed there, you can see that TestStand 3.1 is not supported anymore.
It does work with LV, in your experience obviously even with LV 2009. But only with the developement system.....
A possible solution for your issue therefore is: Update TestStand to the newest version available.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,765 Views)
