NI TestStand
Problem running sequences and code modules from central host on two clients
I have all sequences, vi's, dll's etc. on a central server. I have two PC's in the lab with NI Developer Suite Professional Test edition installed and I want both to be identical test stations. When I try and run my top level sequence on one station it says that the prototype of one my vi's has changed and asks me to edit it in labview. I know it hasn't changed but I open it any way and save it. I then tell Teststand to keep the current values and save the sequence. Now when I try and run the same sequence from the other test station it says that the prototype of the same vi has changed and asks me to edit it labview. This goes back and forth. What's going on here?
kph
(3,065 Views)
I figured it out. It was a path issue to a subvi. I just created a .llb and included vi.lib and it put it on the server. Now it works great.
kph
(3,060 Views)
