Hello Sunny,
When you say you use the method NewExecution, are you using the default VB OI shipped with TS or you created your own? Before calling the NewExcution method you should use the Engine.LoadTypePaletteFiles() method to load the types into memory. Inside those VIs you are calling from your step types, are you invoking LabVIEW methods like quit application, etc? Are you using TS method calls inside this VIs? I guess we need some more information...
Besides that, what if you create a very simple step type that just calls a VI that does nothing inside, does it work?
Roberto Piacentini
www.ni.com/support
