NI TestStand
Problem with Labview VI's
I'm relatively new to TestStand and I'm getting an error when I am trying to initialize a Labview VI. The following error occurs when initializing the DMM:
"Constructor Node in Driver Simulation.lvlib:DMM.lvlib:Initialize.vi->Driver Simulation.lvlib:DMM.lvlib:Initialize.vi.ProxyCaller
LabVIEW: The specified .NET class is not available in LabVIEW.
Error explanation may be inaccurate because 64-bit LabVIEW Run-Time 2016 is not found.
1386; User-defined error code.
Step 'Initialize DMM' of sequence 'MainSequence' in 'Solar Panel Test.seq'"
I am using 64 bit TestStand with 32 bit Labview and I have Teststand adaptors configured to be used with the 32 bit Labview Development.
Please let me know if there's a solution to this problem.
-Jon
Message 1 of 9
(8,634 Views)
Accepted by topic author JLW186
I have figured out the solution to my previous question by adding the configuration file to the program files from this link:
http://digital.ni.com/public.nsf/allkb/4742EB60B64BE22186257BCE0053B8FD?OpenDocument
Message 2 of 9
(8,610 Views)
Thanks for coming back with the solution you saved me some time and headaches.
Message 3 of 9
(8,230 Views)
Hello
I have the same problem for the same exercice. (Solar test Sequence)
I have done the stepts that the link says , but when i execute the .seq in teststand I'm obtaining the error again.
I'm using testsstand 32 bits and Labview 32 bits.
Message 4 of 9
(7,686 Views)
I have already solved
Thanks for your help.
Message 5 of 9
(7,682 Views)
I followed the steps in the link as well but I am still getting the same error.  You said you fixed yours.  How did you do it?
Message 6 of 9
(7,447 Views)
How
Message 7 of 9
(7,173 Views)
@ElPepeMartinez wrote:
How
I am facing the same problem, also tried the same solution but did not work, any other ideas?
Message 8 of 9
(6,933 Views)
We have to follow both the methods. Unblock and create an .exe file. I solved it
Message 9 of 9
(6,281 Views)
