NI TestStand
Problem with VI Packager in TestStand 2.0 ...
Hey guys... I'm trying to package a test for distribution and the VI Packager.vi reports back an error.. Code = 7 with "LabVIEW - source does not exist". It gets about 1/2 way through the process then stops. I'm using TestStand 2.0 and labview 6.1.
I did open a few of the packager vi front panels and found that there was 2 controls that were in a directory that is no longer there or used and I'm guessing that is the problem but I have no idea where the caller is or how to find it.
any suggestions?
(2,864 Views)
Solution is to re-compile the source directory... apparently there were 2 controls that were not saved with the test software and it caused all of the vi's to use the default control which was fine. recompiling the directory solved the problem...
(2,853 Views)
