NI TestStand
Problem with display window and get back the step result
HI,
I am displaying window  programetically using TS 4.0 and C#.NET.Just say message box. Here problem is my program will not wait for the window response. So, I get the step result status is "null" or "Running".
            Please explain me program should wait for result of widow and then program should execute next step?
The followings are step name:
Substitute //Displays window
Print  : Result is Done
Output : Result is Done
Display//Displays msg box// Result is null
Input//Displays msg box // Result is null
Compare // Result is Done
Thank you,
regards
Rkk
(3,158 Views)
Hi Rkk,
Is your is your "window" .NET step modal ?
Can you post a small example ?
Greetings
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,153 Views)
Thank you very much.... I got the result. If I have any problem, will ask.
thank you
regards
rkk
(3,135 Views)
