NI TestStand
Problem with loading a Sequence File - Limited Windows Account
Dear Sirs,
I have a problem and a very less time to fix it; so I'm asking for your kind help.
I have a production PC, with a Debug Deploy License of TS 3.1 and LV 7.1; the operating system is Win XP SP2.
No problem when I login the session with my Administrator Windows Account; on the contrary, when I try to login with a Limited Windows Account, I'm not able to load my Sequence File, and the text appearing is attached to this message.
Someone can advise me a solution to quickly solve my problem?
Thank you very much and Best Regards.
Stefano
(3,347 Views)
Stefano,
if you open files in TestStand, TestStand tracks this in different configuration files (for example for the "most recently used" list). Therefore, TestStand tries to save these changes in the ini-files. It seems to me, that the installationdirectory of TestStand is not permitted to be used for writing for your user login in Windows.
So you have different solutions here, the simpliest being:
Give your user the right to write files into the < TestStand >\-folder.
hope this helps,
Norbert B.
Message Edited by Norbert B on 11-16-2006 07:28 AM
Norbert
Expert: Geometry
(3,338 Views)
You need to do one of two things:
1. setup the rights of the limited user so that you have write access of the Teststand\cfg folder
or.
2. Change the location in the Station Options dialog (as it suggests on the dialog shown on you jpg)
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,335 Views)
