NI TestStand
Problem with report generation
I get no results on the report. The header information is there but non of the body. Any word on what might be the problem ?
Ayman
(3,113 Views)
Maybe you have set the MainSequence to 'Disable Recording for all steps' in the Sequence properties.
Or
Set the Filering on to somthing like 'Passed/Done/Skipped'. with all tests passing you would only get the header and footer.
Can You post your sequence file.
Regards
Ray Farmer
Regards
Ray Farmer
(3,105 Views)
