NI TestStand
Problems running TestStand 4.0 under non-admin account
I am having problems running TestStand 4.0 under a non-admin account under windows XP. I have done the following:
   1. Set full control protection to entire National Instrument directory
   2. tcverselext.exe was giving me problems until I changed it to run in window 95 compatability mode. Otherwise I get an "you do not have administrator priviliges to run this command" error. Don't know if this is the correct fic for this.
   3. Now when starting TestStand I get a "Retrieving COM class factory for component with CLSID {B2794EF6-C0B6-11D0-939C-0020AF68E893} - failed due to the following error: 80040154." error
Everything works fine as administrator.
Can anyone help me?
Don
(3,204 Views)
The Version Selector needs to be run with Administrator Access.  When you are running it in Windows 95 Compatability Mode, you are masking the problem.  However, once you set the correct version of TestStand, you no longer need Administrator Access to use the Sequence Editor.
Allen P.
NI
(3,183 Views)
