NI TestStand
Problems with "msg->GetEvent();"
I wrote a C++ program with the following code:
void __cdecl UIMessageCallback(struct IDispatch *UIMessageDisp)
TS::UIMessagePtr callbkmsg = UIMessageDisp;
long event = 0;
event = callbkmsg->GetEvent();
return;
But when I compile it, I get this error message:
--------------------Configuration: RunAgent - Win32 Debug--------------------
Compiling...
RunAgentComp.cpp
h:\runagent\debug\teapi.tli(8066) : error C2556: 'enum UIMessageCodes __thiscall TS::UIMessage::GetEvent(void)' : overloaded function differs only by return type from 'enum TS::UIMessageCodes __thiscall TS::UIMessage::GetEvent(void)'
h:\runagent\debug\teapi.tlh(6986) : see declaration of 'GetEvent'
h:\remote agent qc\remoteagent 2.0\runagent\debug\teapi.tli(8066) : error C2371: 'GetEvent' : redefinition; different basic types
Error executing cl.exe.
RunAgent.exe - 2 error(s), 0 warning(s)
Who can help me? Thanks in advance!!!
(3,635 Views)
Hi
It looks like teapi.dll is being #imported multiple times.
Can you post a simple project which gives you this error.
Regards
Anand Jain
National Instruments.
(3,614 Views)
From the third line after the header in the compiler report, it seems like you have declared "event" as a long, but the compiler found that "GetEvent()" returns an enum. Look at the declaration for GetEvent to see what data type it returns.
- tbob
Inventor of the WORM Global
(3,610 Views)
Thank you! That was it.
(3,587 Views)
