NI TestStand
Problems with sequence context and W2000
I have a Test Stand 1.0 sequence that works correctly in W98 but I have tried to execute in a PC with W2000 and the sequence doesn´t work. It seems that the problem is with the sequence context activeX pointer.
(2,934 Views)
TestStand 1.0 and 1.0.1 did not support operation under Windows 2000. TestStand 1.0.2 and later did. Are you by any chance using one of the versions not supported? If so, I would recommend upgrading to the latest version which is TestStand 3.0.
Bob
(2,934 Views)
