NI TestStand
ProcessModelPostStep - How to get Name and result of Step?
in the model is a callback sequence "ProcessModelPostStep" that executes after each step.
If i insert in there a MessagePopup -> How can i show the Name and result of the calling step?
(1,299 Views)
Can be access via Step.Name and Step.Result.Status
but beware: Step.Result.Status will always be running since at the point of PostStep, the Status condition has not been evaluated yet
Edit: was wrong on this one. Evaluation has taken place here
in the PostResultListEntry CB is what you are looking for, if you need the status exression to be evaluated
(1,295 Views)
Step.Name only returns the Name of the MessageBox-Step.
I want to show the name of the step the executes teh callback "ProcessModelPostStep"
testplan: mysequence.tpa
contains numericlilmit-test: ThisIsmyTest [Limit 0..10] result 5, Status Passed
Model:
callback: ProcessModelPostStep
contains teststep "MessageBox"
Should display: ThisIsmyTest, 5, Passed
(1,291 Views)
Accepted by topic author OnlyOne
Sorry....
Parameters.Step.Name
(1,288 Views)
One more thing:
Where can i find the parameters that i set here:
1. StepSettings -> Properties -> RunOptions -> Result Recording Option -> Disabled / Enabled
2. And how can i find the type of step if it is a numeric, string, or boolean test?
(1,276 Views)
Parameters.Step.StepType.AsPropertyObject.Name
Parameters.Step.TS.Resultoption --> 0 ResultRecording disabled, 1 Enabled , 2 Enabled override Sequence Settings
(1,263 Views)
