NI TestStand
Programatically Generate new Batch Report
I am using the BatchModel and I have configured the report generation to generate a separate report for each DUT and a single report for the batch.
Between batch executions I want to be able to stop logging to the current batch report and create a new batch report (with a new Batch Serial Number) for subsequent batches.
I've taken a look at he NI_ReportGenerator.seq and the "Model Plugin - Batch Start" sequence has a step ("Clear Batch UUT Report File Path Map") where it sets the number of elements in the BatchUUTStatusPathMap to 0.
Based on context I think what I would need to do was to generate a new batch serial number in the PreBatch Callback of my sequence file and somehow reset the number of elements in this BatchUUTStatusPathMap. The full path (as noted in the NI_ReportGenerator sequence) is:
Parameters.ModelPlugin.PluginSpecific.RuntimeVariables.BatchUUTStatusPathMap.SetNumElements(0)
I just don't know how to access the variable from my sequence. Must I create a model plugin that overrides the specific callback in the NI_ReportGenerator?
Message 1 of 1
(1,281 Views)
