NI TestStand
Programatically access parameter values for a .net module using c#
I have a UI where I can open sequence files to view and run.  The UI was written in c#.  Each of the steps in the sequence files call into .net modules also.  Each call has three parameters. One the paramters is the name of a file that I want to open from the UI using notepad is the user wishes.
How do I get access to the parameter values of the step module programatically?
I have access to the step module object using the fololowing line of code:
Module myModule = this.seqFileViewMgr.SelectedSteps[0].Module;
Once I have the module object, I cannot seem to find a way to get an array of the paramter values via the TestStand API.
Does anyone know how this is done?
Thanks and regards,
Sean
(5,285 Views)
Hello spthornton
Please view the following link:
http://digital.ni.com/public.nsf/allkb/129785F0AFABB90A8625686E005AE407
I hope this helps.  Happy holidays!
Amanda B.
(5,253 Views)
DotNetModule dotNetModule = myModule as DotNetModule;
Hope this helps,
-Doug
(5,166 Views)
