NI TestStand
Programatically configure and generate a second report
We can generate two separate reports for a testand sequence using by adding and configuring a second entry using the report options dialog box (for Eg: XML and HTML).
How can this second report be configured and generated from within the sequence itself ?
For example, I have used the 'reportoptions' callback in the sequence file to define the properties of my Report no.1 and have generated it successfully (as seen below)
How do I add a second HTML report and configure its options for the above sequence ?
Found something similar, but it is applicable for the pre plug-in model report generation era:
https://forums.ni.com/t5/NI-TestStand/Report-Model-Plug-in/m-p/2405836
Thanks and Regards,
Supreeth
Thanks and Regards,
Supreeth.K
Message 1 of 1
(2,167 Views)
