NI TestStand
Programatiicaly determine if a subsequence exists
How do I determine if a named sequence exists in a sequence file (not the current sequence file) and if present, execute it? The file in which the sequence resides may or may not be loaded.
I would like to do this within a TestStand sequence (presumably using the TestStand API). I'm using TS 3.0. I know how to dynamically call the sequence, I just need to determine if it exists before calling it.
(3,141 Views)
Get a reference to the SequenceFile then you can use the API SequenceFile.SequenceNameExists(sequenceNameParam) and this returns a Boolean.
Regards
Ray Farmer
Regards
Ray Farmer
(3,137 Views)
