NI TestStand
Programmatic access to SequenceCallModule.SequenceFilePath
Hi there,
I was experimenting wtih ActiveX steps accessing SeqeunceCallModule. If the UseCurrentFile is TRUE,  SequenceFilePath is an empty string. If I uncheck UseCurrentFile in SeqEdit and put in the seuqence file's path and recheck UseCurrentFile, the following programmtic accesses to SequenceFilePath holds the corresponding string. This behaviour kind of caused me some trouble because I expected SeqeunceFilePath to hold the path, even if UseCurrentFile is checked... that's what it's like with expectations... Smiley Happy
I've kind of worked around this issue, but I'd like to know if this behaviour is intentional?
Cheers
Oli
(3,547 Views)
The property SequenceFilePath "remembers" the last path you entered or wrote via the API. If you set the UseCurrentFile to TRUE, the value is ignored, but not overwritten. ther same happens in the Sequence-Editor. if you enter a string, then check the UseCurrentFile Flag, and uncheck it again, the entered path appears again.
So this is the intentional behaviour.
To get the path of the used sequence file you would have to check the UseCurrentFile flag first. If it is checked, use the path of the used sequence, if it is unchecked, get the SequenceFilePath property.
(3,538 Views)
Thanks André Smiley Happy
your suggestion is exactly what I took to solve this issue.
Cheers
Oli
(3,530 Views)
