NI TestStand
Programmatically Hiding Compatibility Dialog
Is there a way to programmatically select the Don't Show this Dialog Box Again for the Compatibility dialog on TestStand opening? I have found a way to do this if I modify the shortcut using the /NoCompatibilityIssuesDialog command line argument. I want to check this to hide this dialog from my users.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
Message 1 of 1
(1,932 Views)
