NI TestStand
Programmatically Renaming a Sequence in a Sequence File
Hi, I was wondering if there's a way to programmatically change the name (rename) of a Sequence in a Sequence File. Thanks in advance !!
(4,358 Views)
Accepted by topic author arefinm
You should be able to with this method: (assuming the sequence you want to change in in the same file)
ThisContext.SequenceFile.GetSequenceByName(Parameters.OldName).Name=Parameters.NewName
This does not validate it works properly though. You really should verify the new name does not already exist and that the name is valid (contain only letters, numbers, and underscores. Name cannot contain spaces, start with a number, or be empty. Additionally, t name cannot be "Value")
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
(4,345 Views)
Thanks a lot !! worked like a charm.
(4,340 Views)
