NI TestStand
Programmatically changing default value
I use a vi in one step of TS which has default value, let's say 10, and I am not allowed to change this vi at all. However, I want to change the default value from 10 to 100. Is it possible to make another vi which does the trick? For example an action step which does the trick before the step with value of 10? I hope you understand my explanation 🙂
BR,
Jick
(3,620 Views)
HI,
I dont know if it is working during runtime,
but i would access the LabView-Adapter and try to change...
in this thread there is an example that shows how to work with it.
http://forums.ni.com/t5/NI-TestStand/Create-a-LabVIEW-Step-dynamically/m-p/978560#M25825
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,616 Views)
Is this value a control?  What's wrong with just passing in the proper value?
(3,610 Views)
It is a string control. I want to do it for safety reasons. If programmer forgets to change the value she/he could break an expensive system.
(3,607 Views)
