NI TestStand
Programmatically find file name
How can I programmatically find the report plug in being Enabled and its Output Name and then get the file name being currently generated?
I used the attached VI but believe I may not be passing the Engine reference correctly from TestStand to LabVIEW, keep getting error 97.
Thanks!!
CLD
(1,211 Views)
On further investigation I found a way to get the file path using:
RunState.Root.Locals.ModelPluginConfiguration.Plugins[<plugin index>].PluginSpecific.RuntimeVariables.PerSocket[<socket index>].Path
 and even tried:
RunState.Root.Sequence.Locals.ModelPluginConfiguration.Plugins[<plugin index>].PluginSpecific.RunTimeVariables.PerSocket[RunState.TestSockets.MyIndex].Path
 but both return the error in argument 1,
Unknown variable or property name 'RunState.Root.Sequence.Locals.ModelPluginConfiguration'.
Also how to find in plugin index for a given plugin name programmatically? I do see Base.Enable property but how to first find the name of the plugin?
Thanks!!
CLD
(1,189 Views)
Accepted by topic author lvrat
Thanks Davis21, although I am not sure I understand the UriUtils class you mentioned.
After doing some testing the following syntax works for me when calling in Cleanup step of Mainsequence:
Locals.FilePath = RunState.Root.RunState.Sequence.Parameters.ModelPluginConfiguration.Plugins[Locals.LoopIndex].PluginSpecific.RuntimeVariables.PerSocket[RunState.TestSockets.MyIndex].ReportPath
Thanks!!
CLD
(1,171 Views)
