NI TestStand
Programmer for microchip and freescale microcontroller
I want to use in TestStand a programmer for Microchip and Freescale microcontroller.
Have somebody a suggestion about what programmer would be better to use ?
(3,846 Views)
Accepted by topic author chiritab
Hi chiritab,
In most cases TestStand can call external code and is especially useful in calling code created in LabVIEW or CVI. Below I have linked another forum that discusses different ways to program microcontrollers using LabVIEW which can then be used in TestStand as a step in your sequence. Please let me know more about your application so I can better assist you.
http://forums.ni.com/t5/LabVIEW-Embedded/freescale-controller-in-the-LabVIEW-ARM/m-p/766906
Patrick H | National Instruments | Software Engineer
(3,821 Views)
Hi Patrick,
My application is a test system for assembled PCB in production line.
I decided to use programmer PM3 for Microchip and for Freescale micro another programmer.
I will come back with the result or with question if will be.
Thank you.
(3,815 Views)
