NI TestStand
Progress View
Hi    ,
I am using a  Report sequence view in my project to see all the steps of execution   .
The problem is that I wish to make some colums wider by defualt and to not show some colums.
Is there any way I can do the above ?
I've also attached a picture to explain what I mean .
Thanks In Advance ,
Avi
(3,491 Views)
Hi Avi
That looks like an older version of the Sequence View so I am not sure if this method will be valid for the version you have but it can't hurt to give it a try.
In my version if you right click on the Sequence View control, float over 'SequenceView' in the menu and then select 'Properties' from the sub menu.  the SequenceView Control Properties panel will be displayed and this allows you to control the look and feel of the columns as you need.
Attached is a screen shot of the properties panel.  Hope it helps
Regards
Steve
(3,451 Views)
Assuming your UI is based on the examples, you should be able to right click on your sequence view at runtime and select Step List Configurations>>Edit Step List Configurations.
(3,434 Views)
