NI TestStand
Property Export/Import names to each array element in a [Array of containers] ?
is there a solution (i did not find one) to pass custom names given to each array element  through a property export.?
04_Dat {Locals} Bytes_Out {Container [0] .. [5]} Byte1 {String} Byte2 {String} Byte3 {String} Byte4 {String}
04_Dat {Locals} Bytes_Out[0] "Set" 02 hz6 67u er
04_Dat {Locals} Bytes_Out[1] "Reset" 777 77utu 67uki erfgfg
The text marked in Red is what I expect.
(1,249 Views)
I don't think this is possible to do this way.  I tried putting the name inside the square brackets with no luck.
My guess is you could try using an Alias file: https://zone.ni.com/reference/en-XX/help/370052AA-01/tsexamples/infotopics/property_loader_limits_wi...
Or you could see if the source code from the import/export tool is there and modify it.  This would be trickier I think. Code is here: C:\Program Files (x86)\National Instruments\TestStand 2019\Components\PropertyLoader and is written in C#.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,207 Views)
thanks jigg
(1,200 Views)
