NI TestStand
Property Loader: Array of strings
I am looking for an example of using the property loader step to load a labView type array of strings.
Not much in the reference manual...
thanks,
jvh
(3,316 Views)
Accepted by topic author jvh75021
The best way seems to be to export it first.
On the variables pane I created a local array of strings and populated the values while at it.
Then Tools>Import/Export Properties - Source/Dest tab, set data location to file and browsed in a file name. I used tab delimited for Format so I could just type a string per line w/ no qoutes. On properties tab selected the Local array I created. Then hit Export and the file was created. Opened the file, copied and pasted for other cases, and changed markers accordingly.
Thanks go to Chris at NI-Austin.
(3,282 Views)
