NI TestStand
Property Loader Problem - Error -18
I'm changing a working application from testStand 3.1 to 4.0 and I'm having trouble with the Property Loader.
Sequence File: 86-436-01.seq
Property loader step failed to import or export properties.
116 property value(s) were found.
0 property value(s) were imported from 120 row(s) of data
Error evaluating expression:StationGlobals.Mod1_Ch0_gain = (1)
Property does not exist.
Error evaluating expression:StationGlobals.Mod1_Ch0_offset = (0)
Error evaluating expression:StationGlobals.Mod1_Ch1_gain = (1)
Error evaluating expression:StationGlobals.Mod1_Ch1_offset = (0)
Error evaluating expression:StationGlobals.Mod1_Ch2_gain = (1)
Error evaluating expression:StationGlobals.Mod1_Ch2_offset = (0)
Error evaluating expression:StationGlobals.Mod1_Ch3_gain = (1)
Error evaluating expression:StationGlobals.Mod1_Ch3_offset = (0)
Error evaluating expression:StationGlobals.Mod1_Ch4_gain = (1)
-18; User-defined error code.
The similar step that follows works just fine - it uses a different Excel file stored in the same folder.
The beginning of the Excel file looks like:
Start Limits
<StepName> Variable
<Locals> Variable
<FileGlobals> Variable
<StationGlobals> Variable
Mod1_Ch0_gain 1
Mod1_Ch0_offset 0
Mod1_Ch1_gain 1
Mod1_Ch1_offset 0
Mod1_Ch2_gain 1
Mod1_Ch2_offset 0
Mod1_Ch3_gain 1
Mod1_Ch3_offset 0
(4,525 Views)
So what does the file that don't work look like?
regards
Ray Farmer
Regards
Ray Farmer
(4,522 Views)
Sorry, poor writing on my part. That is the top of the file that doesn't work.
The file that does work looks like:
Start Limits
<StepName>    Variable
<Locals>    Variable
Board1    1
Board2    1
Board3    1
Board4    1
Board5    1
Board6    1
Board7    1
Board8    0
FanDirection    1
HD1position    1
SW1position    0
SW2position    0
(4,519 Views)
No its OK, I re-read your post and thought that maybe it was the bad file.
Is it possible to post the file?
Regards
Ray
Regards
Ray Farmer
(4,516 Views)
(4,514 Views)
Ok the problem is that the properties must exist.
If you put the properties in your StationGlobals, then your PropertyLoader will work.
Regards
Ray Farmer
Regards
Ray Farmer
(4,513 Views)
That did it, Ray. Thank you.
I'm not sure why the 3.1 version works but I'm up and running and that makes me happy.
(4,478 Views)
