NI TestStand
Property Loader Works starting from the Second Execution
Hello Everyone
I am using TestStand property loader under TS 2019 to load the upper/lower limits and also the units and offsets in my Testing Sequence from a CSV file.
All the limits for all the steps are loaded properly except only one, which is loaded correctly only starting from the second execution.
In the first execution the initial limits fixed in Teststand are used for that step.
Thank you in advance for your support.
(521 Views)
I am not aware of any issue like you expressed. If you could post an example that duplicates the issue, subscribers might be reproduce and be able to help debug the issue.
So if you look at a report that includes the results from the property loader step for each execution, do you see the property as not being set and then being set?
Example:
Scott Richardson
https://testeract.com
(484 Views)
Hello Scott
Thank you for your feedback.
The issue was that I used the property loader in a subsequence and the test with the problem was in the main sequence.
Once I put the property loader in the main sequence everything works from the first time.
I still don't know why this is happened.
(466 Views)
