NI TestStand
Property Loader and/or Importing variable values
How do I import a .csv file into a local variables container in TestStand?
I.E.  The cotainer would be udpDataIn(Container) with the following variables
index of type number
apply_doNotApply_ of type number
inputInterface of type number
udp of type number
mCastIp of type string
sourceIp of type string
alarmBitRate of type number
redundancy of type number
compareType of type number
redThrHold of type number
suspend of type number
For example if we has a .csv file that contained:
1,DoNotApply, GigE1, 9001, 239.255.90.1, 0.0.0.0, 95, Primary, DataRate, 10, NotSuspended
2, Apply, GigE2, 9002, 239.255.90.2, 0.0.0.0, 95, Backup, DataRate, 10, NotSuspended
Scott Saxton
Motorola
(4,342 Views)
The easiest way is to work from TestStand and Use the Import/Export Tool in the Tools menu.
Open up the Import/Export Tool, select the file format you required, select the variable you want to export udpDataIn.
Unfortunately I believe to Export the Container you have to select the individual elements of the Container, eg udpDataIn.index
(I maybe wrong and I cannot confirm this at this moment in time as I dont have immediate access to TestStand)
When you have selected your TestStand Variable, you can then press the Export Button to create a new file. This will ensure the file generated is in the correct format.
Once you have the file, you can modify the values in the file, then either use the Import/Export tool to Import the new data, or use the PropertyLoader step to load in the new values at runtime.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(4,333 Views)
