NI TestStand
Property Loader does not work for an array element
HI,
I"m using PropertyLoader to load valued into my FileGlobals variables.
The following variable seems to wrok:   BarcodeLabels.Label1
But this varialbe is not loaded:  CCTexpVal[0].fieldExpVal
Any suggestions why?
Attached is the sequence file where the FileGlobals veriables can be seen.
Thanks in advance
Rafi
(3,542 Views)
Hi Rafi,
You need to have a propertyloader step that actuals referencs the variable.Smiley Wink
But maybe you have attached the wrong sequencefile.
Regards
Ray Farmer
Regards
Ray Farmer
(3,542 Views)
Hi Ray and thanks for responding,
It's the right sequence file. The PropertyLoader calling step is in setup section of the the internal preUUT sequence.
I only attached the sequence file so you can see the FileGlobals....may be something is wrong with it. Anyway, I will attach now the exel file that contains the variables.
Again,  the variables that are not set are CCTexpval[0].fieldExpVal.  There is no error, hence the TS recognizes the variables.  It just doesn't load them.  I put a break point just after the step itself and verify the context.  It remained emtpy!!!.
Thanks for helping
Rafi
(3,522 Views)
Hi Rafi,
In PreUUT Setup, there is two steps which are PropertyLoaders.
The first one loads 11 item which are BarcodeLabels.
The second one loads 1 item which is Registers[5].
I can see the extra properties in the xls for AC_2 but I see no code in your sequence that adjust the PropertiesList array that holds the items to be loaded. Therefore the BarcodeLables are the only items to be loaded.
You will need a different step setup for START_AC_2 that includes the additional items eg CCTexpVal or include them the xls file for AA and AC.
Regards
Ray Farmer
Regards
Ray Farmer
(3,519 Views)
