NI TestStand
Property Loader with Excel spreadsheet embedded into a Word doc
I know I can load test limits from an Excel doc using Property Loader but can I load test limits from an Excel table embedded in a Word document? Has anyone ever done this?
(3,020 Views)
Jules,
I looked into how this could be accomplished, and it doesn't look like it is possible using off the shelf methods. Please if anyone figures out how to do that, i would strongly encourage you to write a Community Example . I think your closest work around would be to have the excel document linked in the word document http://office.microsoft.com/en-us/word/HA101208101033.aspx . Unfortunately in this situation, the excel file is still seperate from the word doc, and anyone reading the word doc would have to open the excel through the link to view its contents. Also if you move the document, you have to remember to move or change the path of the link. What is your motivation behind having the Excel Spreadsheet in a word document? I agree it would be a novel Idea, but as of now when you copy the object into the word document, it gets encapsulated by the .doc or .docx, and there is no clean easy way I have found to abstract it out. I also looked into the potential of dynamically linking the excel spreadsheet and word document, so when you would update one...it would update the other automatically, unfortunately this functionality doesn't exist (that I could find). Sounds like a pretty good product suggestion for microsoft though ; ) Keep me updated if you find a better work-around.
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,001 Views)
