NI TestStand
Property Loader works only first time
I am having a sequence file having two tests loading the limits from external CSV file through property loader. When calling this sequence file once from Main sequence, it works fine. But calling the same sequence more than once, it throws error. (Not able to load).
Please can you help in this.
Selva
(3,157 Views)
Is the path to the file changing?
CTA, CLA, MTFBWY
(3,129 Views)
No, Loading from the same path only.
(3,103 Views)
