NI TestStand
Property Loader
Hi
Is there a way to load parameters for steps such as numeric limt test using the property loader?
Currently I believe to acheive this your required to add locals or parameters to a sequence.
Is there a better way while allowing updates to be made from a  text file.
(3,511 Views)
http://forums.ni.com/ni/board/message?board.id=330&message.id=6523&query.id=295997#M6523
In the example at the above link loads the limits for three step.
You dont need any locals or parameters.
The PropertyLoader allows you the abililty to load from a file different properties such as Locals, parameters, fileglobals and Step Properties such as Limits.
Not sure I understand your sentence - "Is there a better way while allowing updates to be made from a  text file."
Regards
Ray Farmer
Regards
Ray Farmer
(3,502 Views)
well, I'm using property loader in my main sequence and it works
I'm also using it in sub sequence, in the setup part but seems it doesn't work, is there any special condition to use the property loader step like at the beginning of the main sequence and not in setup part of sub sequence ?
(3,497 Views)
It should work. Just to clarify, are you saying the PorpertyLoader Step placed in the Setup doesn't work but placed in the Main and it does?
what TestStand version are you using?
Regards
Ray
Regards
Ray Farmer
(3,495 Views)
yes,it didn't work inside the sub step and finally I changed the Load Option to Load dynamically and it works now
(3,483 Views)
