NI TestStand
Property in parallel execution to see if all DUTs exited the Setup
I have an application, where it's important to know that all the DUTs (I have up to 24) have exited the Setup state, before some are allowed to enter the Cleanup? I was wondering if there's such a property, than I could querry on a lock in the Cleanup before executing. Would it be something to do with the Stepgroup?
(4,246 Views)
Hi rsmrostov,
I don't believe there is a pre-defined property for this. However, you could create a variable on the last step of the Setup state (or the first step of the Main state) to set a programmatic flag.
Briana P.
Licensing
Sr SW Engineering Manager | NI R&D
ni.com/support
(4,224 Views)
This would have to be a StationGlobal or a FileGlobal so all the threads can read it?
(4,221 Views)
You are correct. If you would like all threads to be able to access this variable then it should be a StationGlobal or a FileGlobal.
Briana P.
Licensing
ni.com/support
(4,204 Views)
