NI TestStand
Property loader in .csv Format : Error with list of Numbers
I need to change property files from the .xls format to the .csv format so that I won't need to install Ms Office on the Test Station PC.
Everything works is .csv format except for variales containing lists of numbers.  Here is an example.
This variable contains the channel list to send to a Digital Multimeter.  A string containing all channel numbers seperated by comas (The DMM model is Agilent  34070A).
I create a variable named ChannelList of type string containing : "101,102,103,104,105"
When exporting to property file (Using Tools-Import/Export properties), TestStand will write the following line is .csv format :
ChannelList,"101,102,103,104,105"
When trying to import this property value with a property loader I get the following error :
Runtime Error Occured
Error evaluating expression:Runstate.Sequence.locals.ChannelList = (""101")
Unexpected Token: 101
What puzzles me is that teststand is not even capable of reading its own exported property within a newly created file.
Any ideas?
TestStand 2013
Thanks in advance
Nien
(5,189 Views)
Nien,
what happens if you remove the quotation marks in the csv file?
Norbert
Norbert
Expert: Geometry
(5,164 Views)
Hi Norbert,
I should have answered that question in the first place, it's the first thing I've tried.  If I remove the quotation marks, TestStands considers the first coma to be a field delimiter and even though I don't get any error when using the property loader, the content of the string will only be "101" instead of "101,102,103,104,105" after the importation.
Regards
Nien
(5,152 Views)
Other tests also :
TestString,'101,102'
will result in :
"'101" (Notice the ' in front of 101)
No error
TestString,"101"+"102"+"103"+"103"+"104"+"105"
will result in :
"101102103104105"
No error
TestString,"101"+","+"102"
will produce error
Unexpected Token ""101"+"
TestString,"101"+chr(34)+"102"+chr(34)+"103"
will result in:
TestString,"101102103"
No error
(5,149 Views)
Nien,
This is a known issue and we are looking into this issue in future version of TestStand.
There are couple of approaches for fixing the problem:
1. Use a different character for comma in the property loader file. After importing the data, replace the character with comma using TestStand expression in the sequence file.
2. Use Tab Delimited Text format instead of CSV format.
3. We can see that, property loader is using expression to update the value of the property (The exact expression is specified in the error message you have posted). In a text editor, update the csv file to have the value as
ChannelList,101""+Chr(44)+""102""+Chr(44)+""103""+Chr(44)+""104""+Chr(44)+""105
This will create the expression such that, the value of ChannelList property will become 101,102,103,104,105
Note: This is just a workaround and you should use this approach with caution.
Shashidhar
(5,135 Views)
Thank you very much for this very precise answer!
Nien
(5,121 Views)
