NI TestStand
Property loader properties
I can not get the value from the attached excel file.
What are the properties to set in the step "Property Loader" ?
I want to get the value of EngineRPM in locals.
Thanks for your support.
(3,006 Views)
You have only local variables defined in the Excel sheet. So you have to configure the Property Loader to import local variables and you have to make sure that the local variables exist in your sequence as the sheet states.
Do you get an error message?
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,003 Views)
