NI TestStand
Property to tell if process model was run?
Is there a property to look at from a sequence context, where I can tell if the process model was run or not?  I need to programmatically change some initialization in a substep vi, depending on if the process model was run.
Thanks for any insight,
David Jenkinson
(3,611 Views)
Accepted by topic author david_jenkinson
RunState.Root != RunState.Main
or
PropertyExists("RunState.ProcessModelClient")
(3,609 Views)
