NI TestStand
Python Adapter in TestStand 2014
I am using the Python Adapter in TestStand 2014 to send commands to my device and get back values such as voltage\temperature\current. When I send commands that report back a single value, I am able use the String or Number Return Value options to get the values. However, when the method returns a value and then prints out information, TestStand returns an error and I am unable to collect the data.
Example:
Get_Status() returns:
Result: 1
"Voltage: 14
Current: 5
Temperature 30"
I also noticed that after I run the test, if I try to run a second unit (even if it is the same unit), the python seems to lock up and refuse to run any step. Once I terminate and run again (which presumably unloads python), it will work.
Message 1 of 1
(2,079 Views)
