NI TestStand
Python Call Method: How to get bytearray return value
I use TestStand for calling some python methods. These methods are returning bytearray values. How can I collect this return values, what can of local variable I need to use? I have tried to collect the retunred value in array of numbers but I get error:
Error: Error in 'Return Value'.
Failed when tyring to convert field of tuple at index: 0. Inner error:
D:\_w\1\s\Objects\listobject.c:202: bad argument to internal function
[Error Code: -17311, Could not accept the parameters passed in. ]
The FileGlobal_2 var is an empty array of numbers. The type of var that I expect from the python method is bytearray.
Is there some way to do this?
Thank you in advance for the support.
Message 1 of 1
(1,599 Views)
