NI TestStand
RF Sweeping Using VST 5646R
Hi NI-thusiast,
I had a problem with my sweep frequency level. While sourcing a 375MHz to 530MHz with -10dBm of power, no error occurs but when sourcing frequency levels below 375MHz just like the image attached here an error occurs that tells me there is "No source offset was found for power level -10dBm @ 374000000 Hz @ port 1.
Correct me if I am wrong, what I think about this is the calibration of the tester does not consider the levels below 375MHz. The resolution I did, is I calibrate the tester using the 48-Port Module unfortunately that does not solve the problem.
Don
(1,380 Views)
I would also assume that the default calibration does not go below 375MHz.
Santhosh
Soliton Technologies
(1,329 Views)
Thanks for this reminder I will repost this at that forum
(1,314 Views)
