NI TestStand
Randomness of TestStand Random() function
Does anyone know how good the Random() function in TestStand is? If I called Random() in the same sequence running on two different stations, can I expect different values? What kind of random-number generator is it, and how is it seeded?
(5,672 Views)
The random generator is the same one you can find in the CVI toolbox.fp instrument driver, which includes the source code. I think TestStand takes the default seed, so that you should get the same sequence on different stations. However, you should confirm that empirically. I don't think TestStand has a way to reset the seed or reseed from the clock, so I'll enter a suggestion for that.
(5,672 Views)
You are correct. The same numbers come out every time I restart TestStand. As a workaround, I can start my sequence with a loop that burns through some number of Random calls based on the clock and maybe a hash of the station id. That should be good enough for my purpose.
(5,672 Views)
