NI TestStand
Read Only Palette
Hello
Does anybody know why my palette is read-only ? and how to write in it ?
I tried to change the right under Windows, but I already have the right to modify the palette file.
I tried to run TestStand as administrator, but nothing changed
Laurent
(2,372 Views)
Type Palettes are loaded when the application manager starts.  So thus when TestStand first opens.  My guess is that after you change the Windows permission you need to restart TestStand.  BTW- I've only ever seen it show this when the Windows permission is set to read-only.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,330 Views)
