NI TestStand
Read Test Steps in a sequence.
Using Test Stand 3.5 and C#.NET.  Need to know how to read all test steps in a sequence.  Does anyone have examples on how to do so programmatically?
(3,668 Views)
Hello Bobby,
here is example code for getting sequence steps in C#:
IEngine engine = this.axApplicationMgr.GetEngine();
SequenceFile seqFile = engine.GetSequenceFileEx("YourSeqFilePath", GetSeqFileOptions.GetSeqFile_OperatorInterfaceFlags, TypeConflictHandlerTypes.ConflictHandler_Error);
Sequence seq = seqFile.GetSequenceByName("MainSequence"); // Steps in MainSequence
int stepCount = seq.GetNumSteps(StepGroups.StepGroup_Main); // Steps in MainSequence
for (int i = 0; i < stepCount; i++)
    Step seqStep = seq.GetStep(i, StepGroups.StepGroup_Main); // Steps in MainSequence
    ...... // Your code here
engine.ReleaseSequenceFileEx(seqFile, 0);
Regards
MY
(3,645 Views)
Code example works great.  Couple more questions....
1. The Test Stand sequences were developed with CVI.  When I run the code and get to the line in your example
SequenceFile seqFile = engine.GetSequenceFileEx(YourSeqFilePath, GetSeqFileOptions.GetSeqFile_OperatorInterfaceFlags, TypeConflictHandlerTypes.ConflictHandler_Error);
it opens a dialog box and I have to search for a few DLLs.  Is there a way to add the DLL path or include them so this won't popup every time?
2. Can you filter out what type of steps the sequence contains?  Meaning, if I wanted to only see the Numerical Limit type steps in the sequence?
Thanks again.
(3,637 Views)
Hi Bobby,
to your first question: i think the GetSeqFileOptions "GetSeqFile_NoOptions" should be right for you.
to your second question: you can get the step type for a step and the name of it.
Try following code instead,  and let me know if it works.
SequenceFile seqFile = engine.GetSequenceFileEx("YourSeqFilePath", GetSeqFileOptions.GetSeqFile_NoOptions, TypeConflictHandlerTypes.ConflictHandler_Error);
    StepType stepType = seqStep.StepType;
    string stepTypeName = stepType.Name;
// StepType in String
Regards
MY
(3,631 Views)
The GetSeqFile_NoOptions did not work, but I figured out what it was. I did not have my search directories setup correctly.  When I tried opening the sequence in Test Stand it asked me for the DLLs, as well.  To fix it, I had to click Configure -> Search Directories and add the directory where the DLLs were stored.
The step type and name helped.
Thanks again.  You provided the info I needed.
(3,627 Views)
