NI TestStand
Read and write txt file
Hi
I am writing a teststand sequence that can publish a device's serial number into a text file or ini, (or publish it into the environment) and then having another teststand sequence to read that file or grab that environment variable.
I can't just combine the two teststand sequences because I have to run a program in the middle and I need the console output of that program on cmd (and potentially jenkins).
When I'm publishing it to environment variable using SetEnvironmentVariable(String, String, EnvironmentVariableTarget) function, I get a .net fatal error from teststand.
I am able to write into a text file from teststand using cmd, but I am not sure how to read from it in the 2nd program.
Please help ~  and thank you in advance 🙂
(4,191 Views)
Have you checked out the method in this forum post for reading from text files in TestStand?
Lindsey Nestor
Program Manager, Hardware Services
(4,153 Views)
Hey, thanks for replying. I did check that out but it didn't seem to work for me. Fortunately I was able to pass in the variable into command prompt so all is well 🙂
Thanks again.
(4,150 Views)
