NI TestStand
Read local & globalfile variables in TestStand 3.5 & using C#
How do I read (and write) file globals and locals from C#? Code snippet below desn't work.
//Get process model file globals
SequenceFile
aSequence = axExecutionViewMgr1.Execution.GetModelSequenceFile();
//aSequence = axSequenceFileViewMgr.SequenceFile.GetModelSequenceFile(out modelDescription);
//Get fileglobals for sequence file
PropertyObject
aProperty = axExecutionViewMgr1.Execution.GetFileGlobals(aSequence);
//Get Order Id (in file globals)
string
anOrderId = aProperty.GetValString("CurrentOrderId", 0);
I've done it before in VB6 (and TS 2.0) and there it works fine, se below snippet.
    Set myExec = myEngine.NewExecution(Nothing, aSequenceName, aModelFile, False, ExecTypeMask_Normal)
    'Get process model file globals and the order report object
    Set aSequence = myHelper.myExec.GetModelSequenceFile
    If Not (aSequence Is Nothing) Then
        'Get fileglobals for sequence file
        Set aProperty = myHelper.myExec.GetFileGlobals(aSequence)
        If Not (aProperty Is Nothing) Then
            'Get Order Id
Message 1 of 1
(3,156 Views)
