NI TestStand
Regain focus
good morning
I am running a TS2 sequence under sequence editor,
my step is an LBV7 Action which runs some window application.
after the window application terminates
the screen looks as in the attached file,meaning, LBV window covers the TS2 window
and i mannully have to minimize it, otherwise i cant see TS2 activities.
my question is, how to set the focus again to TS2 so it will cover the LBV window?
thanks in advance
Simon.I
(3,386 Views)
This is quite an old problem and there is not a lot you can do about it, other than migrate to TS3.1.
You can try having LabVIEW running and minimised before you start executing your test sequence.
Have you done a search on the forum, I know there has been discussion on this.
Regards
Ray Farmer
Regards
Ray Farmer
(3,382 Views)
hi simon,
I tried running the demo example computer motherboard test sequence using TestStand 2.0.1f1 with labview 7.0 running in XP SP2 and I had not problems with the LabVIEW coming to the top. as per you jpg attached.
I know I have had this problem but that was with LV 5.1.1 and 6.0.1 running in NT and Win2000, but like I said in your previous message, it was usually the first time labview was launched.
Regards
Ray Farmer
Regards
Ray Farmer
(3,343 Views)
